@CRISTHEILLEST GEN 2 BUILD THREAD
cristheillest
Bay Area
What's up everybody! Think it's time I get going with this build thread and show you guys what I've done to my truck within the 5 months of having it. I can say that this truck has by far been my best purchase, I love this thing! If you guys have instagrams, ya'll should add me! I do post a lot of my car projects there almost daily! Give me a follow @cristheillest
Jump to page 4 for Chase Light DIY
https://www.fordraptorforum.com/threads/cristheillest-gen-2-build-thread.94607/page-4
Jump to page 4 for VHF Center Console DIY
Let's start from the beginning; I purchased this truck back in June, it is a 2019 Performance Blue Gen 2 802A package, fully loaded. It wasn't long before I started modding it, typical car guy extracurricular activities :driver:
First things first, I hate riding around in water bottle cars so I tinted the windows within the same week. Went with 5% all around cause if I'm going to get a ticket might as well make it worth it!
A couple days went by and my order finally arrived, ended up purchasing the Borla Atak exhaust, Cobb CAI and Access port for the 91 OTS Tune. I was really surprised on how much different the truck performed after the OTS tune, kind of a bummer the Raptors didn't perform like that from the factory. But anyways, below are a couple pictures of the installation, pretty easy/simple stuff.IMG_0565.jpgIMG_0568.jpgIMG_0872.jpg
cristheillest
cristheillest
Bay Area
A couple weeks went by and ended up making another order, purchasing the JLT oil catch can and Baja Design LP4 along with the SDHQ A pillar brackets. Same deal with these, pretty simple install
IMG_1646.jpgLook at this babies, they're so well designed!! Also, for those of you doing your own shit like myself, keep in mind you will be thrashing most of the wire harness that comes with the kit, after trimming this is what I was left with which then connected to the auxiliary switches.
Once wired up, the results are pretty neat! :happy160:
IMG_1900.jpgView attachment 378489
Once the lights were done, onto the easy install - JLT oil catch can
cristheillest
cristheillest
Bay Area
A couple more weeks went by and pulled the trigger on Eibach leveling springs for the front. Now I've done springs swaps in the past, but after reading through some of the DIY's on this forum I started to get a bit nervous about the install as people were making it seem a lot worst than it really was.
I am here to tell you that the install was not bad as everybody thinks, just get yourself two sets of spring compressors, an impact gun, extension and you'll be set. Now when installing these, make sure to only turn each of the rods a bit at a time going in a crisscross patter - And well, obviously take precautions too, at the end of the day a sketchy job is a sketchy job. The hardest thing about this job was literally removing that stupid strut tower nut way in the back, where you have no room to get your fingers in.
Here is the right shock removed next to the Eibach spring
This is what I did, 4 mac strut spring compressors centered on the spring, notice they are each set one run below the other. Did this to apply even pressure through the compression area.
Couple more days went by and finally decided to knock out the bead lock rings on the OE wheels I have, I personally like these wheels so I figured why not, I do plan on off-roading a lot so **** it why not
NOW THIS INSTALL SUCKED!! SO FREAKING REPETITIVE
20+ bolts being torqued again and again is not fun, but ehhh, suck it up and do it
cristheillest
cristheillest
Bay Area
Now time for some trail upgrades. I got a Lake Mammoth trip with some of the NorCal group in a few weeks so lets install some of the necessary items.
Ordered a VHF radio along with the third brake light antenna mount. I ended up going with the Bullet Proof Diesel antenna mount keeping my OE brake light, I'm not a fan of the big chase light bracket holding the S2 lights, personally I think its too bulky but that's just personal opinion.
Once installed, I got going with the radio install inside of the center console. I ended up going with a 50W Anytone radio
Now let's start getting real creative now. I recently started getting into carbon fiber part making so I ended up making skinning an extra set of mirror caps I had laying around.
This was definitely a learning process! Never messed with carbon fiber and I actually screwed up like 3 times LOL but the end result was pretty sick.
If you guys want a set, let me know!! I started making extras!! The carbon fiber was skinned directly on the mirror cap so you won't be at risk of somebody ripping them off. I recently had a buddy get his stolen as the ones they sell online are installed using double sided tape. The carbon fiber and epoxy were bonded directly to the mirror cap.
cristheillest
cristheillest
Bay Area
My most recent mod happens to be the Baja Desing S2 chase light install with custom brackets I made from scrap metal i had laying around in the garage.
I used 3/16" stainless steel plates, which then I cut and drilled to be installed directly on the bed.
Once properly cleaned up, I painted them black so they could blend in with the finish of my bed. Also painted the hardware that came with the lights. While the paint dried, I began drilling the 4 holes on the bed and I used rivet nuts to be able to properly secure the lights to the bed. IMG_3936.jpg
Once the rivet nuts are installed the the brackets mounted, its time wiring to get done but you guys don't need to see that!
As you guys can see, it's been a busy 5 months for me. I do everything myself, I got plans to upgrade the suspension next but for now this will do! More posts to come :grd:
Antho
Looks great and good choice on upgrades. Only thing i would have done differently where the chase light mounts. Only because i hate drilling holes in the truck. I use the swarfwork mounts and they are perfect. Not knocking just wanted to let you know there are decent options available without having to drill!
cristheillest
cristheillest
Bay Area
Thanks man! I saw those but honestly don’t really care about drilling 3/8” holes, it’s very minimal, the only thing about drilling these is to make sure the lights won’t be covered by the tire rack but I’m building a custom rack so I’ll be fine!
Antho
Again, not knocking it. I think it looks great. Just wasn’t sure if you knew about other option. Keep it up! Great wheel choice too! I liked them so much I had to buy a set for the gen3!E73784E2-6230-4488-80B1-2187D82B0F08.jpeg63B36B13-DA77-4469-AD02-36B1DF08D614.jpeg
