GEN 2 Unofficial Official Rays Wheels Thread!
RS-R
North Carolina
Looking at the TE37 for my Gen3 37 PP - will a 13.5 tire have a lot of cutting to do to not rub? Or is the consensus to stick with the 12.5 wide? Any input would be appreciated!
c4sxm5
What tires size/brand is everyone running on the TEs? Have a set of 18x9 -1 coming and need to get tires ready... Thinking Nitto 37x12.50R18 but just wanted to see if there were any other options to go bigger?
JaviNES
Miami, FL
Purchased a second gen and looking to swap over to a TE setup like most on here. Currently it has installed Vorsteriner 20 inch wheel with a 35x12.50R20LT nitto ridge grappler tire. Not terrible of a setup, just not what I ultimately want.
My question is, would you expect the 37 inch tire and TE setup most of you are running be an issue coming from the above spec? If my calculations are somewhat correct, there shouldnt be much of a difference, ~2mm at most.
Krazykorean
Mesa, AZ
There will be a 2inch difference. You will need to trim a little. I think you are mixing up the Rim diameter to your current wheel to the TE 18inch, yes the wheels are 2 inches smaller but going to a 37inch tire will make your setup 2 inches bigger.
JaviNES
Miami, FL
You know what, youre absolutely right and I apologize for the extra chromosome I mustve had yesterday.
That being said, any body running a 35 inch tire on the 18 inch TE's they can share a pic of? I saw the ZE40 setup with 35's but not a TE setup.
Staff online
93,130
56,406
NoahE
