Headlight
4x4TruckLEDs.com
I am looking to switch my halogens headlight bulb with LED bulbs any suggestions where to get them ?
If you need to replace your H13 halogens, check out our CrystaLux Bulbs (use coupon code RAPTORFORUM and save 10%): https://www.4x4truckleds.com/crystalux-led-headlight-bulbs-for-ford-f-150-2004-2014/
If you want to get a REALLY nice set of lights, check out the Morimoto XB (message me for pricing)
Amber DRL: https://www.4x4truckleds.com/morimoto-xb-led-headlights-for-2009-2014-ford-f-150-amber-drl/
White DRL: https://www.4x4truckleds.com/morimoto-xb-led-headlights-for-2009-2014-ford-f-150-white-drl/
They also have a Hybrid version which is less $$ (and a bit less light then the XB): https://www.4x4truckleds.com/morimoto-xb-hybrid-led-headlights-for-2009-2014-ford-f-150/
CoronaRaptor
CANADA
Do those bulbs require resistors for our early gen 1's, or do they come with the bulb kit? They look pretty bright in the pictures.
bubbarob
DFW
Recently installed the Morimoto headlights and they are amazing. Absolutely worth the money in my opinion.
Had them on a few past trucks, and the Gen 1 is the easiest install I've done.
