Mechanic is Stumped - Battery Drain
WellingtonB
Dripping Springs,TX
After reading the existing threads for similar issues, we are nowhere closer to a solution.
2012 SCREW 135K miles
Dead battery every morning (very dead). Replaced with new battery and tested charging system. No problems with either.
Code Pulled = B10F1 (ignition switch short). Mechanic could not start truck with new ignition switch. Will be checking tomorrow to see if it needs some sort of software reset.
Other items already checked and found to be ok (at least this what I was told): gauge cluster, shift solenoid. Initially, they did check all circuits by pulling fuses and thought they found a draw in the gauge cluster. Seems they dismissed that for the moment. They haven’t chased much of anything else as it seems they are focused on the code.
Truck has been at the shop over a week and don’t want it there for months like some of the other members have experience. Any new ideas out there? Obvious stuff we’re missing? Potential recall?
Thanks all!
CoronaRaptor
CANADA
Found this video, pretty much same as your issue. He mentions you have to reset it. Hoping they fix it.
GCATX
King Dingaling
Central Texas
Does it have a key to start or just a button? If it's a key, then it could be the ignition switch in the steering column. In the old days with keys, they did some weird stuff when they wore out.
WellingtonB
WellingtonB
Dripping Springs,TX
Looks simple enough. Hoping they can reset the system and be in business.
Yes, a key.
wheelman55
Big Bend or MN
Not certain if this helps with a Gen 1.
I had bad diodes in an alternator in my 93 F250. The battery drained every day. Worked great after I replaced the alternator.
These drain issues are hard to track.
FordTechOne
Detroit
A common battery drain issue on these trucks is the park detect switch. Monitor the gear indicator in the Instrument Cluster (IPC), if the red P is not illuminated in Park, then the IPC is not receiving the park signal from the park detect switch. This causes the IPC to remain powered up indefinitely, which drains the battery.
WellingtonB
WellingtonB
Dripping Springs,TX
The "P" does NOT light up in the gauge cluster. No, the mechanic did not check this (although I asked them to while they had it). Went and checked it myself. It was tough. Had two climb into the truck, start it, and use both eyeballs to search for and find the non-existent "P." Did it all on my own and didn't even need a boost into the cab.
I will search for a fix unless someone has good link handy.
Just got the truck back without being fixed. Going to keep fuse #11 out until I can figure this out. May have to do it on my own as the mechanic is stumped. I am fairly mechanical, but with busy work schedule and a toddler - I have zero time for this.
WellingtonB
WellingtonB
Dripping Springs,TX
