- Joined
- Jul 15, 2017
- Posts
- 1,043
- Reaction score
- 941
We decided to compile and configure some reverse kits for you to make your life simple.... and offer some GREAT value and price advantages over any other options out there.
We want to cater to ALL tastes... so we have Baja Designs S2 kits.... And Rigid SRL kits.... AND Diode Dynamics SS3 kits.... (We can also put together an S1 kit if people would like) If you want something bigger, we do have the full size pod kits like Rigid Radiance/Scene, D-Series Flood, Squadron, etc available....
(Take note. Our tail light adapter INCLUDES diodes, so no backfeed regardless of the configuration you choose)
Here is a link to the Baja S2 kit..... You will notice that for the same price, you get our plug n play tail light adapter INSTEAD of cutting into your factory wiring with a splice... But you also have a lot more options...
CLEAR ADVANTAGES OVER THE STANDARD BAJA REVERSE LIGHT KIT #447558-
Here is a link to the Rigid SRL Kit.... You will notice again, you can choose our tail light adapter, full length harness or both...
CLEAR ADVANTAGES WITH THE SRL REVERSE LIGHT KIT-
Here is a link to the Diode Dynamics Kit.... You will notice again, you can choose our tail light adapter, full length harness or both...
Coming soon...
Features for the SRL and the Diode Dynamics versions with the red backlights....
The Tail light adapter supplies power to BOTH the Reverse WHITE light and the RED backlight on separate wires. So the Red backlight will trigger with the tail lights, marker lights, and lock unlock flash.
We think this will give our Raptor (And these are available for many other vehicles) a CLEAR advantage over any other offerings out there.
Our Patent Pending Harness system has truly changed the game when it comes to "Plug N Play" Options....
NOTE: For those of you UPGRADING to the 2021... These rear kits APPEAR to be compatible for the 21 models. We have a 21 on order now and will verify, or at the least, make a version that will fit. If that be the case and you do get the kit for your 17-20 and take it with you. We will be able to help you adapt it over to a 21/22 when the time comes.
Here is a video on the tail light adapter feature..
Let us know any questions you may have...
John
SPVparts.com
317-93-GO-SPV
info @ SPVparts.com
SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit
NEW! SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit The New SPV Raptor Reverse Light kit utilizing the Baja Designs S2 lights are Here!! The advantage to these is the extra slim case. If you want similar light output and less bulk...
specialtyperformanceparts.com
- Your CHOICE between the 1130 Lumen S2 Sport (Which come in the Baja kit #447558) or the PRO version with 2,450 Lumens, which ISN'T available in the Baja branded Kit.
- The Baja Standard kit requires splicing/tapping into your factory Harness for the reverse trigger. Most don't want to do that. Our kit comes with 3 configurations. All of which require ZERO cutting or splicing into factory harnesses.
- Reverse triggers use our plug n play tail light adapter. It plugs into your tail light and then into the rear light harness. All plug n play. All options listed above require zero modification of any factory wiring.
SPV Parts 2017-2020 FORD F-150 RAPTOR RIGID REAR SR-L SERIES REVERSE LIGHT KIT (NO DRILL) SRL rear light kit
Purchase new Rigid reverse lights for your 2017-2020 Ford Raptor at Specialty Performance Parts! Our light kit comes with your choice of harness.
- 1452 Lumens for the Main light PLUS a red backlight. With 1452 lumens, it fits in between that of the Baja S2 Sport and Pro, and adds the red backlight.
- There is no such kit offered directly by Rigid, and the Baja Standard kit requires splicing/tapping into your factory Harness for the reverse trigger. Most don't want to do that. Our kit comes with 3 configurations. All of which require ZERO cutting or splicing into factory harnesses.
Coming soon...
- Your CHOICE between the 1130 Lumen SS3 Sport or the PRO version with 2,898 Lumens (Both versions include a red backlight)
- The Baja Branded kit requires splicing/tapping into your factory Harness for the reverse trigger. Most don't want to do that. Our kits comes with 3 configurations. All of which require ZERO cutting or splicing into factory harnesses.
John
SPVparts.com
317-93-GO-SPV
info @ SPVparts.com
