Why 8,200 lbs tow?
Raptor37
VA
Wondering why the Raptor is regulated to 8,200 lb tow capacity. Is it purely because the rear suspension is a bit softer?
Looking at specs from an engineering standpoint, I would think this thing should rate to tow like most other F150s, if not better... Raptor has 4:10 rearend gear ratio, same 3.5 Ecoboost that is in F150s that rate to tow 12k+ albeit more power in Raptor, and has the full tow additions like trailer brake and backup assist.
Can anyone shed light on this for me? Is it more of a vehicle class rating or is it simply due to softer rear suspension?
dixonk
HMFIC
Oklahoma
Just putting a few hundred lbs in the bed of a raptor will have it squatting a couple inches already. I am pretty sure it has to do with the soft suspension.
DFS
USA
In what engineering vacuum do we disregard the suspension for a tow/payload rating? You can throw 1000 lb/ft of torque in the Raptor or TRX, but the suspension is going to be the limiter. Can't isolate independent variables that way in a system based rating.
It's almost entirely the suspension if you look at the Raptor versus standard F150.
Oggie
California
From MT: "That's not to say that the Raptor isn't a competent tow rig, rather that Ford has been required by the standards to which they test towing ability to rate the Raptor lower than its F-150 brethren because of the truck's soft suspension, taller ride height, and large tires."
EMY92
Woodway, TX
Braking is also a concern for the Raptor, the 17" wheels don't leave a lot of room for brakes.
Raptor37
Raptor37
VA
Yes, totally makes sense for a payload amount playing a part in tow capacity. Odd how ditching the leaf springs increased that BTW. Wonder if the new ride is a bit stiffer...
xlr8
Tejas
Well leafs don't necessarily mean a heavier tow rating. A Ram 2500 uses springs and has a much higher payload than an F150 or Raptor. Just saying the coil doesn't necessarily mean less weight. I'm excited for a coil in the rear, it should ride better and be quieter.
EMY92
Woodway, TX
Also, check what the tow rating for the Dodge TRX is, that will provide the real reason why the tow rating increased 200 pounds.
I'm not sure if the Raptor brakes are the same as the standard F150, I remember a video I watched that interviewed a Ford engineer about the Raptor when I was purchasing my 2018.
93,145
56,419
TwistAir
