Ever seen this happen???
1BAD454SSv2
HELL I ZONA
From the cover it looks like the center pin came loose from spiders started walking out , thrashed cover. That chewed up slot lines up with about where pin is.
Ricoman
WASHINGTON STATE
Nope,never seen a Differential blow thru a cover,but I did put 2 Rods thru the Block and Oil pan of my 383 stroker motor,and that wasnt a pretty sight either.>!!:bawl:
Sounds like I caught my whining sound BEFORE I got to the mess you got.Had a bad bearing and small chip on gear...had entire Differential rebuilt for $1200,which I thought was a good price,and put a Dana Cover on,so if it ever does blow will it be contained .. ;)
MTF
Celebration, Florida
Nice, if your gonna do it do it right. LOL
Cooked all the inner bearings at 20,000 miles, had it warrantied, thank goodness, it was close to $3 grand to replace everything.
Now I have an AFE cover and Mobil 1 gear oil, all is good now.
Jakenbake
If it gets too expensive there is always a full float rear end that can be thrown in there........... which will be more expensive.
1BAD454SSv2
HELL I ZONA
I definitely considered the currie. But for few grand less than the currie i got stock axle completely rebuilt plus front suspension work 4 new ball joints new iwe and leafspring work as well as new mounting for the axle anti wrap bar. OP be sure find good shop with good warranty
BlueOvalF22
Willow Springs, CA
Launched one out the side of a 4G63 block. The GSX was tuned for 1/4 mile in the summer not subzero rally car driving.
John813
PSL/Jupiter
Im impressed.
Only story I can add was that I snapped all 8 rods and bent 7 pistons in My lightning. Multiple holes all throughout the block. Fun times.
Think the cause of failure was a bad hi-low fuel pump relay, tons of boost and nitrous.
Fun times.
