GEN 1 Eibach +3 front springs
Big Blue
Administrator
Staff member
Admin
USA
Just did the same to my truck. Eibachs up fronts and icon rxt springs rear without the added leaf and it sits perfect. Ride is excellent no more rear chatter over bumps
Looks perfect, are the front shocks at OEM low perch or are they at mid-perch with the Eibachs?
P.S.; You need to dovetail that rear.
GunnyMac
Lake Villa, Il
Hello, from all the research I’ve done and read, your shocks have to be set all low perch for the Eibach springs.
II Sevv
Arizona
The stock fox shocks are valved to perform best at mid perch. Ford set the stock shocks to low perch from factory to meet federal pedestrian impact height regulations. Also, alignment cams don’t do anything but assist in keeping your alignment over time, and providing a greater distribution of torque. I have king 3.0’s cranked up to about top height and have uniball non-adjustable upper control arms and have not run out of stock camber/caster adjustment. Unless going far past top perch in height, adjustable arms are a waste of money.
93,145
56,419
TwistAir
