Raptor28
Long Island NY
I found the same or similar socket usb mount as you have and already ordered it off Amazon. Great idea man and ill jump on the install this weekend or early next week. I might do a quick write up with pics if there's enough need by members on here
Sent from my SM-N986U using Tapatalk
That would be pretty cool
EastEndAngler
Long Island, NY
Interested to know if you'll still be able to close the cover. They also make a dual USB with a small Voltmeter built into it.
Donovan
DC
Sauce...
Anyone got a link for these? I cant see a ******* thing backing up... You would think they would install brighter ******* lights in 2020, since its been DARK SINCE THE BEGINNING of time.
I put Black Oak spots in the rear and ran the wiring through the frame to the upfitter switches.
What part of the frame bud? Got any photos? and which switch did you connect it to? Photos of that?
FDHog
NJ Shore
There are openings in the frame rail. I fed the wires through them enclosed in wire loom. Took a lot of patience.
Ran it up the passenger side engine compartment and hooked them into the upfitters. Wired into a 10amp cause they draw 3 amps apiece.
WoahItsRob
Virginia
It looks like it shouldn't be an issue. I'll be able to tell you in the next week. I ended up getting the same setup the previous guy did.
I saw the voltmeter ones but I didn't go for it as it doesn't seem necessary for my setup
Fordraptorrrrrrrr
Idaho
Was trying not to buy anything for Black Friday but caved, ordered an AWE 2FG H pipe for the gen2. Wanted to wake up the sound of my truck w/o getting obnoxious and spending a ton of $. Hopefully this does the trick!
