Oldfart
Ford doesn’t do “Band-Aid fixes”, not sure what you’re referring to. If a dealer performs an improper repair, that’s on them. The OEM can’t control 100% of what independently owned dealers do.
The majority of buy backs are due to dealers misdiagnosing the issue or a parts delay. I have personally repaired vehicles that had engines and harnesses replaced only to find that the tech swapped the intake and exhaust cam sensor connectors, causing them to believe the original issue was still present. I’ve seen multiple transmissions be replaced and for a spread pin terminal in the harness. I’ve repaired intermittent network concerns caused by the customer spilling a beverage in the center console. I’ve diagnosed engine performance issues that were ultimately found to be caused by rodent damage.
Per the law in most states, all of those qualified for a buyback based on repair attempts or time out of service. Yet in none of those cases was the vehicle a “lemon”; they all could have been repaired on the first attempt.
A true “lemon” is a vehicle that cannot be repaired, or repairs are too invasive to restore the vehicle to like new condition. For example, the customer complains of a noise, and it’s found that the bulkhead was improperly welded and would require thousands in structural repairs. Or the customer complains of an odor, and it’s found that water has been leaking through missing seam sealer and the entire interior needs to be replaced and chemically cleaned.
Buying a buy back vehicle does not mean you’re buying a “lemon”, it only means the vehicle qualified for BB under the law. If you have access to all of the repair history and what ultimately resolved the issue, you can get a great deal. But if you’re not technically savy or you can’t get the whole story, you’d be better off not taking the risk.
It's almost like you're pretty knowledgeable about this stuff!
