Broken deavers?
CROOKS
Anyone else have their deavers crack and fall apart? Three leafs on the driver side broke and fell off and one on the passenger side
Less then 3 years old
CoronaRaptor
CANADA
That's a first. Did you jump it really hard. Deaver will most likely offer you a replacement one. As @Oldfart said, contact Deaver, they are nice people. Let us know what happens.
Deleted member 12951
When you installed the Deavers what did you do with replacing the factory bump stop on the frame?
Did you purchased an OEM replacement that works with Deavers like the Forged Off-road’s? Or did you get a full bump stop kit installed?
CoronaRaptor
CANADA
I was just thinking the same thing, it looks like they broke off 3 years ago!
Yes, you can see the metal fatigue surrounded by more rust then actual metal. I think the op has a case for new deavers, if he decides to contact them. OP: suggest if you put new deavers on, that you use some sort of rust protectant on them, like fluid film or equivalent. Those could of been a bad batch though.
DEAVER +1 (714) 542-3703
