FordTechOne
It might be termed "excessive" for the 3.5 Ecoboost, but I've had engines that go a quart/3-4000 miles... My old man had an E90 335Ci and the factory said quart per 800 miles was "totally normal"... zero usage between oil changes is like Camry-level car world. I would expect a high-strung power unit like the 3.5 HO would use some oil between changes. I don't know what the typical Raptor is doing on that front ... but I'd say anything at 2-quarts or less between change intervals is probably not "bad/excessive."
Besides, I don't know how long I've been running w/ this cracked valve cover. Could be that's been the source for all my "consumption" up until now.
You don’t want Camry level oil usage, unless you like burning a quart every 1k miles and having the manufacturer deny there’s an issue:
https://www.classaction.com/toyota-oil-consumption-defect/
As far as oil consumption, per Ford’s TSB the 3.5 should not consume in excess of 1 quart within 3,000 miles, so 1 quart every 2,000 is considered excessive. Keep an eye on your oil level and let us know if the replacement valve cover fixed the consumption issue.
