Triple Bezel Fog Lights - No Longer Working
Imoxfordwhite
Raining cats and dogs here in Houston this week and I had to unfortunately venture out yesterday. I was driving down a dark side road when I noticed only 1 single fog light was working. (Out of 6)
Everything was working perfectly last week when I tested them, normal conditions.
I have them wired up :
Aux 1 - two outer small lights
Aux 2 - two middle lights
Aux 3 - two inner lights
What's throwing me off is only one light works when I have Aux 1 activated and I get nothing when test 1,2,3. (I've tried multiple combinations with no success)
Any idea where to start or what's the potential issue?
Kit:
OFFROAD ALLIANCE - TRIPLE BEZEL FOG LIGHT KIT W/ BAJA DESIGNS SQUADRON PRO
TheTeej
Denver, Colorado
Fuses for the switches maybe? You could try swapping the harness around at the working light to see if it works on the other switches.
DanT
North Texas
Check your fuses - double check your connectors to the switches - I had a bad one and kept blowing the fuse
REX111
Sussex
It’s a light bulb. It only needs 12v and ground to light up. If you do have 12v and ground at the bulb then the bulb is most likely bad.
Winchester30
WI
“Any idea where to start or what's the potential issue?”
How about starting with OFA customer support, they’re excellent.
