sandman_kw
central PA
lol, i guess. my uncle is an anesthesiologist and his words to me prior to college were don't do what i do...be a crna or a perfusionist...i guess i took it to heart but often wonder what if...
chi_weezy
Well-Known Member
Attempted to install the ADD ACC relocation bracket. Everything was going great until I was ready to put it all back together and the factory harness will not reach to the module to the new location. I even tried unclipping the harness from the two mount points but it just isn’t long enough. Drilled another hole in the bottom of the grill to give me more length, nope still not happening. Apparently the module in the 17/18’ was different and figured the harness reached on those.
Does anyone make a pigtail extension or have others cut the 4 wires and spliced in more wire to extend it? This is for a 2020.
i have a 2019 and used the ADD bracket above the R in the grill and it reached. Was tight but reached
Deleted member 12951
Perhaps its different on the 2020 because there was no way it would reach and I tried. I ended up cutting and splicing in more wire and ran it up the middle of the grill so you don’t even see the wire.
Johnfaeglasgow
Kansas
Who’s ACC bracket is that?
It’s a Bajamod bracket, but I used a ADD adapter plate from their kit because my sensor is the smaller style which didn’t fit right. I was going to make my own adapter but i just couldn’t find the time...
I had limited options because of my lightbar
