need to replace front diff bushings
B E N
Frederick, CO
Transfer case transfers and splits power to front and rear. AWD trucks have them as well.
The transfer case in these is electronically shifting, it does engage/disengage the front driveshaft. 4wd selection activates the IWE and selects front output and high or low range.
Glad to see your progressing, tenacity pays dividends!
aka grumpy car stereo guy
well i fired up nosbusa since its been sitting a week. went and got some friction modifier. will see how it worked tonight on my drive home. diff is definitely secure now. no more wiggle and rattle. im hoping thst was the last rattle. write up to come when i find time
FordTechOne
Detroit
question. i cant get friction modifier tonight. didnt know i needed it. am i ok to drive 40 miles without it? need to go home and then back here in the morning where i can get some. just highway and city streets. no offroading.
@FordTechOne if you are around, a little insight would help. i also have 80w90 gear oil as stated in the supplement ok to just fill and leave room for the 4 oz of modifier tomorrow?
No friction modifier is required for the front axle. Friction Modifier is only used in clutch based limited slip differentials.
Jakenbake
Would a Torsen diff not typically Require friction modifier because it does not have the clutches like a plate style limited slip?
