Connecting Rigid to DT Conmectors
4x4TruckLEDs.com
Hey John
Is that backlights on with ignition or lights on? Will that method work with BD S8 back lighting?
Thanks
Baja has a back-light kit you can add-on if you wanted to run the amber back lighting. It taps into your fuse panel under the hood, so less places to run wires to. Our Radiance + 360 series fog kits also include (at no charge upon request) the fuse-tap harness as well BTW
But here is the Baja tap: http://www.4x4truckleds.com/baja-designs-wiring-harness-s8-backlit-add-on/
it includes a few different size fuse taps plus the extension harness
JohnyPython
Canada
Thanks. I’ve run fuse taps in my car for gauges. They work well.
Specialtyperformanceparts
Specialty Performance Parts, John I did buy my Rigid Radiance amber kit with the brackets and harness back in 6/19 from you, I guess I must have missed that when I ordered my kit. It sounds like the best option
We are constantly coming out with now or improved kits and parts. I don’t think I had that put together quite yet in June of 19.
John
Fireguy144
New York
You want Baja Designs then. If you want bright, go with Squadron Pros
Squadron Pro Wide Cornering
Squadron Pro Driving/Combo
Squadron Pro Wide Cornering, Amber
This gives you bright lights for bad weather (amber) and good weather. The Driving/Combos are great to light up everything. If you aim the Pro Wide Cornering down you CAN get away with running them on the street, just make sure you aim them down.
With our triple fog kits we give you EVERYTHING you need. From our USA made Brackets (which offer the most adjustments out of any other bracket out there) down to our wiring harness, which is a solid 1 piece harness that lets you control all 3 pairs from 3 different upfitters.
Use coupon code FOGS and you'll save even more $$
I see you're from NY, where abouts? Our warehouse is located here on Long Island so if you are local, you can even swing by and pickup your kit in person.
https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
Hi... yes I'm from Queens NY. Where are you guys located on long Island?
