Connecting Rigid to DT Conmectors
Fireguy144
New York
Hi guys... looking to get fig lights for my 2019 Raptor... what are the best fog light kits iu there ? I want them to be really bright... i don't car if they're not street legal.
Thanks in advance..
4x4TruckLEDs.com
Thanks in advance..
You want Baja Designs then. If you want bright, go with Squadron Pros
Squadron Pro Wide Cornering
Squadron Pro Driving/Combo
Squadron Pro Wide Cornering, Amber
This gives you bright lights for bad weather (amber) and good weather. The Driving/Combos are great to light up everything. If you aim the Pro Wide Cornering down you CAN get away with running them on the street, just make sure you aim them down.
With our triple fog kits we give you EVERYTHING you need. From our USA made Brackets (which offer the most adjustments out of any other bracket out there) down to our wiring harness, which is a solid 1 piece harness that lets you control all 3 pairs from 3 different upfitters.
Use coupon code FOGS and you'll save even more $$
I see you're from NY, where abouts? Our warehouse is located here on Long Island so if you are local, you can even swing by and pickup your kit in person.
https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
OffroadAlliance.com
Boston, MA
Thanks in advance..
For that OEM fit and finish look, our triple bezel kit is very popular! Stuffed full of Baja Designs lights or Rigid, it's a great setup. Our kits are stainless steel, bolt right in and our wiring harness is plug and play with the all major brands of lights.
Plenty in stock, free shipping and no sales tax for NY.
Let us know if we can get you setup.
PH ---->>>> 888-466-8991
Web ---->>>> OFFROADALLIANCE.COM
Specialtyperformanceparts
How is everyone making this connection? I have the kit from OffRoadAlliance.com (great service so far, will write a review after install).
I’m thinking about soldering them together and then heat shrinking.
I agree, I do wish Rigid had put connectors on them. The thing with the 360, Radiance and Scene lights are, aside from the SAE model you have there, the others have 3 wires. So the 2 way connectors don't work well because you still have 1 wire to connect. That being said, you can use a 3 way connector on the 2 wire SAE but just use 2 pins.
We have worked on harness options for a while now and have some great options available and coming. That being said, we came up with a 6 light plug kit. This has all 6 3 way DT connectors for the Lights AND all 6 3 way male connectors for the harness AND all 18 pins for both that are crimp on. Then, you just slide in the pin, push on the clip and you're done.
Here is a link to JUST the FULL plug kit-
https://specialtyperformanceparts.c.../3-way-plug-kit-for-rigid-radiance-light-kits
The other option is the new Buildable Harness we manufacture which is like a lego set. You simply connect any plug you want. The base connector is a heat shrink sealable bullet connector on each side. You can seal them down or even slide additional heat shrink over them if you're really particular.
The harness works like this. You pick the plugs you want, and simply plug them in.
In the case of the 3 way, you would also get the additional ends that you can crimp on your light wires just like the plug pack above.
https://specialtyperformanceparts.c...17-19-optional-custom-raptor-fog-harness-2017
To understand the harnesses even better, you can watch this video-
Hope this helps,
John
richnot
Central New Jersey
I have a question that has most likely been answered elsewhere, if you use the Radiance back lighting lights can you wire the back lighting to come on with your light switch by tapping into possibly the grille lights or somewhere else?
Would rather just have it wired to an up fitter switch for the light itself and not for the back lighting
aka grumpy car stereo guy
probably go to the parking lights with a relay. its in the passenger kick panel.
You can also use our backlight wire kit which needs no relay and is ignition powered for the backlight. Here is a link and the video-
https://specialtyperformanceparts.com/products/rigid-radiance-backlight-wire
John
richnot
Central New Jersey
Specialty Performance Parts, John I did buy my Rigid Radiance amber kit with the brackets and harness back in 6/19 from you, I guess I must have missed that when I ordered my kit. It sounds like the best option
JohnyPython
Canada
