Any tips on removing the sill plates on 2020 Screw?
Oldfart
Oldfart
Respect. Actually trying to not break $hit and all.
WTF, it’s 38 minutes on and you don’t have finished pics posted yet?
I have the film getting developed down at the drug store.
If you are using the stock tweeter location for your Morel's than I would do it like @smurfslayer said. Put the crossover in the back seat bench area by the amp. Run the mid speaker like to the stock wiring harness and than just a brand new line for the tweeter all the way up. This way you don't need to run new wire into the door. The door plugs aren't what they used to be.... I'm assuming you are using a NAVTV Zen A2B?
So far, I'm running stock amp & head unit, with an Lc2i, Morel speakers and Skar sub.
lateralis
Oregon
Ahh... so you're going that route... Ok never mind that won't work lol...
So I'm guessing you are just adding an amp for the sub only? Morel's off of the factory amp?
You are going to need some 18ga wire to run the door connectors if you want to mount the crossovers in the door. This is unless you are comfortable butchering the the stock harness at the stock amp or the kick panel to interrupt the stock speaker wires.
Here is what I did to run new line. You don't need to double it up like I did since you only need it for the tweeters. Look for the empty holes in the connectors and make sure there isn't a dead ended pin on the door side. My front drivers side had 2 empty pinned spots. Than use like a pick tool to widen the hole a bit and shove the wire through.
Oldfart
Oldfart
Yes, the Skar come with it's own amp and enclosure. The Morel's I plan on running off the factory amp, the tweeters in the stock location. I had planned on putting the crossovers in the rear and run line just for the tweeters.
Hopefully I don't regret not going all in. I mostly listen at low to medium levels. I just wanted to add some fullness and clarity. I was actually pretty happy with the system once I wrapped the sub, and was tempted to stop there, but you always want to fiddle a little more!
K223
Florida
I’m very curious on how it sounds,
Once your done. Really just curious on how those Morels sound on the stock amp and head unit power.
What version of the Morels did you choose?
Oldfart
Oldfart
I got the Morel Tempo Ultra 602 from Bruce @Hush Car Audio. I'll defnitely let you know. Member @GCATX put them in his truck and was happy with them. He's the one that helped me make up my mind.
Hush Car Audio
Aubrey, TX
The Morels you got are really nice speakers. I've never once heard anyone complain about them. They sound like really expensive speakers and can pound out some midbass easily.
K223
Florida
I’ve been considering these. Really wasn’t sure if I was going to use them in bandaid mode with the stock B&O system, and hope for decent improvement in sound quality. Or maybe weight until I revamp the whole trucks system. So very curious to hear about how they work with the stock system.
Hush Car Audio
Aubrey, TX
They work well with the stock system but will be handicapped due to the stock tuning from the B&O system. There will be a decent improvement to justify the purchase. It might make you want to see what it's full potential can be though since this improvement is pretty decent. It only gets better.
