Traffic22
SF Bay Area
Finally got my bed divider finished. Stole the idea from a version I saw on the F150 forum.
In case anyone needs it, the dimensions are 2”x10”x64 7/8. The relief cuts at the bottom are 3” (3” up, and 3” in, cut diagonally)
It’s in there very tight, no wiggle, or wobble.
3-1’ sections of e-track spaced 7 1/2” from the edges and 7” apart. 3” from top of board.
Painted with a cheap can of Rust-Oleum. The cheap board from the Depot was very wet, and I’ve got a little bubbling. If you do this project, spend the extra few dollars and get kiln dried. (I may have to repaint or seal and repaint if it gets sticky.)
edubpdx
portland, oregon
I had my local LINE-X installer properly finish the bedliner on the tailgate that the dealership did a half job on. Got my rear wheel wells sprayed as well, all for $250.
I also installed my candy apple green Powertank to my Builtright industries bed side rack. It was a real bitch to do. Thanks to MacK88DO for the idea and pics!
I’ve got before, and after pics of my tailgate.505d61b2de40cd78c4dcfc7e5d28f6f6.jpg
DINOZR
Southeast
Used Forscan for the first time. I programmed
DRLs set to parking lights only (must confirm in daylight tomorrow if changes took)
Double horn honk disable
Panic button requires 2 presses to activate (it activated in my pocket while leaning on the truck last week--never again)
Lincoln fold mirrors
Heated and cooled seats and heated steering wheel controls displayed on head unit
I have to say, I'm still curious if I got the DRLs right. Can anyone confirm that the Forscan mod below on a 2019 Raptor will give me parking lights + marker lights when selector is in the "auto" position and truck is in drive? My desire is to have all the amber on the truck turned on all the time, except the turn signals.
JAndreF321
Lacey, WA
RCI Rack and Roof Top Tent (Sort of)
Every single lock nut on the roof top tent stripped. Either the stripped on install or when I tried to remove them to get the bad bolts off. Looks pretty though
Deleted member 17706
Went down the dynamat rabbit hole today. Got the driver side done. 3 left to go :)
Let me know if you notice a difference in road noise. I just did my back cab last week. I was looking into buying the door panel cover that one of the members is selling while also wrapping all my doors.
Aviator150
Well, this is my 3rd SCREW and 2nd Raptor. I just installed the Builtright seatback release. Yaaaay. Oh wait, there is no room for storage with the subwoofer and amp. Oh well, first world problems. I'd rather have the space under the back seat.
