Headlight trim removal
John Rathjen
SWATDOC
USA
Hey guys - is there anything tricky about removing the headlight trim/surround pieces?
Are they just installed with clips and just pull out, or are there any hidden bolts?
don't want to break them while removing
Thanks
Removing completely, or popping to pull the grille?
I’ve not pulled them completely, but have pulled them loose to remove the grille a few times and the inside just pulls loose with clips.
MGA
Haymarket, Virginia
Any chance someone has the part number for those clips? Lost one on the middle piece that extends into the headlight, thank
goblues38
STL
We use to call them "Jesus Clips" back in my car stereo days. Because you had to "Pray To Jesus" the clips don't break when you pull them off.
