Does anyone run LCA bumpstops ?
Ben Lucas
Defiance ohio
Does anyone run lower control arm bumpstops ?
Are they worth it ?
I’m currently running Geiser springs on rebuilt 2.5’s and don’t plan on moving up to 3”. Just seeing if anyone would recommend LCA bump or not.
Booth9999
Idyllwild
Depends on how hard you are running your truck. Are you bottoming out the front? If so then could be a positive, I would like them but might just step up to a new bypass shock next to the Coilovers.
Ben Lucas
Ben Lucas
Defiance ohio
I can be hard on it at times. Most times not but that’s why I was considering front bumps as a cost effective way to control the front end.
R
Rick@FreedomMotorsports
I believe Rick @RDFTS is running them or at least he was. Rick, any insight?
Yep, I sure do. And we are a Forged Off-road reseller so I can take care of the package for anyone too.
It definitely makes a difference. My post is here about my thoughts:
https://www.fordraptorforum.com/posts/1396788/
At RTO earlier this month, they definitely came into play too with the amount of jumping and cornering.
