2019 USB Accent Lights
REMIX
Sarasota & Jacksonville, FL
So today my USB ports inexplicably stopped working on my drive home. First time that’s ever happened. After letting it sit for a while they started working again.
I now notice there is no accent lighting around the USB ports and I swear it had them before. Maybe I'm imagining things? Am I losing my mind? Anyone with a 19 can you tell me if we are supposed to have lights around the front USB ports?
Really starting to wonder if that hub is developing an issue.
CHMP
Santa Cruz
I had the same feeling about my 19, that originally the part around both USB ports lit up blue but then stopped. After doing some research here it turns out that Ford did away with the USB light in the hub on 19+ raptors. I ended up swapping the whole hub out for this:
https://www.amazon.com/dp/B081YX5237/?tag=fordraptorforum-20
It lights up which is sweet, and the USB-C connection is great since I have a Pixel.
REMIX
REMIX
Is it weird that I seem to recall these lighting up?
I saw that part, however it says "Sync 3.4" only. I'm on 3.3 I believe.
CHMP
Santa Cruz
Yes it works with 3.3. I bought it after a recommendation I got from another forum member who was also running 3.3.
