GEN 2 Cordless charging with Apple CarPlay?
Solidred
So. Cal
Also, same goes with skipping tracks or any other functions based on the steering wheel controls. What I’m reading is that those with work with the dongle. I’m definitely interested iffffff I’m not losing the convenience factor there.
tested with Siri worked just like when plugged in...tested forward and reverse track skipping with amazon music and it works like it’s plugged in album art and all....once now it shows it’s connecting and after 30 secs it does not, unplugging and plugging back in it connected within 10 seconds. That’s the last first time so far it did that and another poster in another forum said same thing maybe 1 out of 10 times...heard there were connection issues with remote start as well and last night (1 remote start so far) it worked without any connection issues. I’m pretty impressed with it and happy about my purchase
alphatwox
North Carolina
Let me know after a bit how it’s working. I may have to break down and buy it ;)
Solidred
So. Cal
playing with it longer, it’***** and miss as far as connecting every time on it’s own. I’d say 50/50. Simply unplugging and replugging in solves the connection and makes it worth it, in my opinion. If you like CarPlay you’ll like this device.
alphatwox
North Carolina
50/50 sucks, however my feelings change a little bit knowing it’s just a simple un- and replug of the adapter...not tooooo terrible.
Solidred
So. Cal
ya it isn’t ideal but it’s worth it, I’m hoping an update to the adapter happens to fix it, who knows
Solidred
So. Cal
Learned you don’t have to replug it in, you can select the adaptor from Bluetooth settings
traxem
Almost easier to unplug it vs leaving the CarPlay menu and back to Syncs screen.
I got a USB toggle switch. Makes it easy to cut off wireless car play or if I ever have to reset the connection (rarely needed unless I’m trying to use the Sync Navigation).
I’ve used the wireless car play adaptor for over a month now. It’s been great. I ended up ordering a second one for my Benz.
HENGSHENG wishacc Male to Female USB Cable Adapter with On/Off Switch-Upgraded Support Power and Data, USB Extension Inline Rocker Switch for Driving Recorder, LED Desk Lamp, USB Fan, LED Strips https://www.amazon.com/dp/B07QTJZD99/?tag=fordraptorforum-20
