GEN 1 Steering Rack Replacment - Notes and Info
EricM
OHIO
Dealership telling me that leak - have exact same one
is AC Coolant leaking from Compressor... WTF?!?
It could be- there's oil in the A/C system. If your compressor has a freon leak, the oil will leak out with it. If it's that oily though, I'd think your AC would be nonfunctional by now.
B-C
CenCal
Agreed -
AC works - Probably does have some minor leaks -
but the only thing i've seen from that is typical Condensate
and from the image not that oily but like you said - not that much freon in the system and that amount of oil out of a compressor would be ALOT.
m3dragon
m3dragon
Orangevale
Nope, sent the rack to a builder who took it apart and the only thing they could see to help was different guide rings. Other than that the rack is not great for upgrades or fixing. New rack is only option =(
riberware
Miami, Florida
What happens if I install a steering rack pinion from a SCREW (145" wheelbase) on a SCAB (133" wheelbase)?
Any experience with this?
SCREW racks are widely available and cheaper.
RLTW
TX
It’s fine, I’ve had a screw rack in a scab for years, it turns a little quicker, some might find it more twitchy at higher speeds.
