Found that Damn Rattle
Refugio
South Texas
Finally
Had this rattle coming from behind front seats that sounded like rear seat latches or rear seat belt buckles hitting the doors while not using.
Would hear this rattle when driving over slightly bumpy or rough roads and driving very slow. Or on an uneven surface while truck was flexing.
Was not the following things.
Not the Jack behind the seat
Not the rear sliding window
Not the tail gate
Not The Retrax rolltop cover
Not the rear doors latches or panels
Not the gas tank skid plate under the truck
Nothing loose under truck
Not the rear shocks.
Not the sliding sunroof.
It was the rear glass panel of the sunroof that does not move. Found it by geting in the back seat while wife was driving and holding a little upward pressure near the back of it.
Fixed it by loosening four of the six screws that hold it in place. Just a little. Then slighty repositioning the panel up and down a tiny bit but making sure it was put back exactly where it was. Also, I lubbed the rubber seal with some of that special lube.
I actually think it was the lube alone that fixed it.
Completely quiet now
Completely happy.
hammer73
Hillsboro, Oregon
Well done researching. It’s a known problem. I can confirm... lube the seals of the roof window and problem is gone.
Krytox GPL205 Performance Lubricant Grease
Amazon can supply...
Refugio
Refugio
South Texas
Yes
That is the exact stuff I used and purchased thru Amazon.
Thing is...that I purchased the lube a couple of months ago and had lubed all the way around the tilting/sliding glass as preventive maintenance as I have done with vehicles with sliding moon-roofs only in the past.
But I did not lube around the rearward fixed glass panel. Never had the second panel like on this Raptor.
Anyway....just happy that I finally found the rattle noise and its now quiet.
MDJAK
NY
I have the same rattle. Figured it was the rear sunroof glass. I’ll try and put lube in it. I have that stuff. Ty
Badgertits
Ma
How exactly did you lube the rear panel? Removed it?!? I mean I got the section that mates to the front sliding panel but obviously not the rest of kt
RonPorter
El Segundo
Easy, just run a small bead of silicone based grease along the edge of the rubber seal and the painted roof. Tool the bead with your finger. Rattle and squeak will be gone. Do the entire seal around the moon roof. Its good practice to keep that rubber lubed and maintained.
dilmorecg
Seattle, WA
I have this with my sunroof too. Dealer lubed it up once already but it came back within a few days. Really common with F150's. If you google it there are a few DIY fixes. I haven't had the chance to attempt one on mine yet.
