- Joined
- Jul 18, 2017
- Posts
- 2,851
- Reaction score
- 1,315
Off-road alliance has a rear cover for that.
That's not going to prevent mud from getting back there
Yup! The new modern designed optics make a world of a difference. These are due to start shipping 12/06! We will also be running a sale on DD for Black Friday, so stay tuned!From your pictures, the SAE fog looks pretty impressive. What’s the ETA?
with the current issues with Baja Designs SAE not being in compliance,
They are on a stop-sell because they aren't in SAE compliance, so BD is redesigning the lens and reflectors as we speak. No word on exact dates they will be ready to sell again, but I was told two weeks and a week has passed since our conversation.are the current issues with the Baja Designs SAE? Source?
Question.....if I go with the relay, the three light combo in the bumper and the S8 (driving combo) behind the grill, what combination would you recommend in the bumper? I'm thinking SAE (to be on anytime the headlights are on - either low or high beam) and two driving combo's to be on whenever the high beams are on. Then the only time I'd use an aux switch is when I want to turn on the S8's (but have the driving combo's in the bumper also on an aux switch just in case), and hopefully the three light combo inn the bumper wouldn't be too much when my high beams are on - and the S8 in driving combo would provide the spots that I'd give up by having two driving combo's in the bumper instead of one driving combo and one spot. I don't see myself being in a situation where I'd want to run a spot in the bumper but not want to be running the S8 at the same time. Make sense? 95% of the time I'll be on regular roads in regular driving situations. The other 5% I'll be driving backroads where I'd have the chance to utilize the S8's (or going very slowly through the woods when going hunting). My only concern with this is the mud and the bumper lights, but I definitely want some SAE's somewhere to help legally whenever my low beams are on. If the driving combo's become too much when the high beams are on, with the relay could I just remove the diode and have them activated with an aux switch? Or should I go with Racer Spots on an aux switch instead of two driving combo's in the bumper and have the Racer spots to give extra long distance light that the S8 wouldn't provide?Hey Jeff, welcome to the club.
So I'd recommend the following setup for you
-SPP Triple Fog Light Kit w/Baja Designs Lights
-Squadron SAE Wide Cornering
-Squadron Pro, Driving/Combo
-Squadron Pro, Spot (or if you want the LONGEST distance, Squadron Racers would do the job, but i tend to like the spots better as they have a bit more coverage, although not as FAR as the racers). Racers are good if you are racing around 60mph+ on back roads.
I'd also grab the LVJ Motorsports Relay Panel here: https://www.lvjmotorsports.com/product-page/gen-2-hi-beam-modified-relay-panel
The reason for the LVJ is that, while you don't need the relay system for power, you'll want it for the ease of tapping into your highs. LVJ lets you pick/choose which wires can turn on with your highs. So you'd wire your lights to the LVJ, then wire the upfitters to the LVJ. You can then change a diode to pick/choose which circuits come on with your highs.
So you could leave the SAE lights on at all times via the switch, then wire in say the driving/combos to activate when your highs are triggered (or even the spots as well). I have customers who trigger their LP9 lights when their high beams come on (for me, my LP9 low mode trigger when my highs are on).
It's a nice setup. Plus our SPP Triple Fog Light Kit lets you pick/choose lights if you are not happy with the setup I recommended. You can really pick/choose what lights to go with. We include stainless steel brackets and an all-in-one raptor specific wiring harness as well.
It's available here: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
For reverse, can't beat the Baja Designs reverse kits. I run the S2 Reverse kit on my truck here: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s2-reverse-light-kit/
But we also offer this with the new Baja Designs S1 lights. The S1 lights are smaller then the S2 and offer about 2x the brightness as the S2 Sport: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s1-reverse-light-kit/
Now your truck has upfitters, but if you want that 3 hole panel, we stock them here as well: http://www.4x4truckleds.com/center-console-switch-panel-for-2015-ford-f-150/
You'd have to run wires to your upfitters and battery though using that 3-hole setup.
Here is our demo truck showing our SPP Triple Fog Lights and those LP9s I told you about. It might give you some ideas for future lighting as well.
Just shoot me a message if you need help or text me. Contact info is below
