Overland Raptors
Cory s
Orlando fl
Post em if you got em
I will be doing the transamerican trail in June for 3 weeks. I’ve laid my truck out in my head a hundred times. Would like to see some others set ups.
Simplejack
dallas tx
ADD has a rack on bed of there raptor at Sema show. Should have more info on that in couple weeks.
badm0t0rfinger
Rocket Man
The Beach
The low profile rack is great if the only thing you put on it is a RTT or stuff that doesn't extend over the cab like a bike. I have longboards and kayaks on my rack more than an RTT so I opted for a taller one that allows things to clear the cab.
Vegas_Sirk
Boise, ID
Good point but couldn't you just stick those in the bed? The problem with RTT is they add a lot of weight high up which affects handling and fuel economy. Thats why I personally like it behind the cab. I also like that set up as the rack comes off easy for days you need to load tall items in the truck (like buying a new BBQ), and works with a roll top cover.
TheClaw
Maricopa, AZ
Keep a look out on the dynamic weight limit if you plan on overlanding or trailing with the rack on. As the frames might break under pressure. We have aluminum beds that flex. Llod has a video on racks and his broke on his taco. I’m a fan of the skybox mini since it’ll fit over our beds. But won’t be available till March 2020
badm0t0rfinger
Rocket Man
The Beach
Completely agree with the RTT adding weight, and increasing center of gravity but say you use the RTT twice a month is it really worth it to have your rack only be able to be used with the RTT? Plus for me having a rack that goes above the cab works. My 8 foot surfboard hangs out almost 2 feet when angled into the bed, let alone my longboard. My kayak wouldn't fit at all. However I have mounts for both on my rack.
Compared one of shorter boards (7'6") in the bed...
and on the rack.
Does it have its downsides? Yeah for sure, the RTT is a bitch to get on and off, but honestly if I found myself in a position where I needed my RTT all the time I would just get a trailer.
adllewis42
Seattle
I don't know how much "overlanding" I do, but we get around. In the past,I had a Retrax tonneau cover with a KB Voodoo rack. The setup was great but when I 'm trying to take my wife, my kid, and my German Shepherd, it doesn't quite work for us. I swapped it out for a Snugtop and I'm much happier. I think I'm gonna change the tent too but that's another story. I'm debating on if I want to add a bed slide or not ...
Vegas_Sirk
Boise, ID
and on the rack.
Makes total sense. I guess it just depends on your needs. I don't surf living in Idaho, but I'm out in the mountains camping all summer long so the RTT would be on the truck all summer. In the winter it would be off and Front Runner racks have ski/snowboard mounts that I can swap on to it for my gear and the roll top cover will keep the rest of my stuff dry and out of the snow.
In the end I guess it just depends on personal needs.
