WINCH INSTALL FOR 2019 Ford Raptor
Carmine Genovese
I am looking for advice on what winch mount to buy using the stock bumper and not relocating the Intercooler...Help?
Joe12345
PA
MTF
Celebration, Florida
What about getting a front receiver hitch installed and getting a winch adapter hitch mount.
I've seen a few guys do that, makes sense being able to pull in either direction without extra pulleys and snatch blocks.
amREADY
Victoria, BC
Thanks guys. Did talk to Warn today and they are contemplating a winch mount for that year...... Thanks will keep exploring!
Did you mean Warn is going to do a winch mount for the gen 2 Raptor or they won't? You said they are, but then said you will keep exploring, so wasn't sure if it was a typo or not?
Swarfworks
Michigan
Unfortunately you have to move the intercooler, because the stock sits exactly where the winch goes. But I look at it as a bonus because it gives you another good reason to replace that weak oem ic.
lilgsx96
WA
I just put mine SWARFWORKS mount and winch in today along with the COBB intercooler. I will say it both the COBB and SWARFWORKS kits were 100% bolt on. No modification need to either kit to make it fit and work! If you do what the instructions tell you to it will all line up and fit.
Blockaderunner
Orlando
I saw a setup using a front receiver hitch mounted to the frame below the tow hook and the guy was using a Warn winch mounted on the removable receiver frame. FYI
