TSB 13-6-8 Transmission
Ocbuckeye
SoCal, Orange County, Irvine
Add mine to the list:
Here is My Recall Nightmare, Long story but need some help guys.
I was heading out of SoCal a few Saturdays back with my father and son in the truck. April 6th to be exact.
2013 Raptor SCREW with around 98k miles on it (Dealer-installed Roush). 2nd Raptor, shopping for my 3rd (Gen2)
I’m roughly 2.5 miles from the house doing about 55-60 MPH and the truck feels like it shifts into neutral, revs, stutters and then slams into 1st gear. The Truck skids and revs high RPMS before I can get my foot on the brakes driving in the middle lane. I get the cars around me to stop so I can get over to the side of the road/bike lane.
I limp the truck home and start looking online to see if I can see what's up. After some time I ask my dad to call Ken Grody Ford in Buena Park. While he’s on the phone he says to the service tech that he should talk to me. The Service tech then says that the earliest they can get me in is May 27th. Over a month later, I push him several times to tell me why so long when he finally lets me know that” We take care of our customers first”. Now I didn’t purchase the truck there, or my 2014 ruby red, I did purchase my Flex Titanium from his Carlsbad location, I purchased my 13 at Paris ford in Texas and my 14 at Goody ford in Idaho, But as far as I’m concerned, since I’m driving two fords currently, I’m a Ford customer. I also work for one of the largest Automotive media companies in the USA and have been directly involved with Ford on projects for their Advertisement, Leads, Marketing, and Auto Show products. I’m a Ford guy and always have been since I bought my first Ford in high school(1970 Bronco). When he tells me this I’m pretty shocked.
So then I call up Auto Nation Ford in Tustin and Ned says they can have the truck in on Tuesday Morning. Great. Tells me there is a recall and that they will look at it.
Tuesday morning, Drop the truck off, dad waits for it a couple of hours to update it and they give it a wash, check off all of the inspection boxes that truck is in good shape and he heads home. I was told there was no codes and no issues with the truck.
NOW, the whole way home (about 6 miles) the truck can’t find the right gear, shifting up, sticking in third and then to 6th and back into 3rd. Throwing the wrench code all the way. I'm at work so I head home to inspect it with him. We can’t find anything wrong with it visually, nothing leaking, but the same transmission issue after it initially locked up. So dad takes the truck back to the dealership. The truck sits there till Friday and I finally get a call from Ned telling me that My Supercharger belt is shredded. Now we checked the belt at the house before taking it over, and apparently, they did too when it was at the dealer for the update because they checked off that all belts were good when we picked it up from the initial recall issue.
The next call I get is that the Service writer says they can’t find a belt. After a bunch of back and forth calls trying to figure out how a truck with good belts leaves the dealership with a fixed recall issue and is returned with a shredded belt, a generator code and a hot temperature code and a non-functioning transmission. Back and forth some more we decide that I will drop off my own belt(They can’t find one locally, I have two) and they will put it on. They obviously can’t diagnose the transmission issue without it.
  • SO, they put the new belt on, drive the truck and say it STILL has the transmission issue but has no codes.
  • They can’t do anything now UNTIL there is a code(Ford says it has to be there to repair)
  • I’ve been driving the truck several times now over many days trying to get a code to persist but nothing
  • I can bring it back with the wrench on but don’t know if that will work
  • The dealers not returning any calls
  • I had no issues until this thing locked up going down the road on April 6th and now it's undrivable any long distance
  • Any suggestions to help get a code to persist?
  • Any suggestions to help me get this thing fixed?
  • Either the leadframe is bad and won’t throw a code or the lockup from the recall damaged my transmission.
Thanks, Guys sorry for the long read
Crash33
The lead frame issue doesn't always throw a persistent code. Usually with the first occurrence, you get a wrench and truck will stay in 1st or 5th gear. When you turn off truck, wrench may be gone along with any readable codes. the only way to retrieve any code is to leave the truck running when transmission fails and get it to dealer still running with wrench lit. I believe this was originally an in house TSB, but has been elevated to an NTSB safety recall. I would try to search it out from that angle. Good luck.
Ocbuckeye
I posted this in the TSB thread also but if your wondering if this is your issue here is a short clip of what my truck is doing.
Here is a video of the instrument cluster and a visual of what is happening when the truck is going down the road. The wrench is thrown but there is still no persistent code after you turn off the ignition. As you can see as I’m driving down the road at 30 mph, the transmission in the truck is in 6th gear and tries to shift into 1st. And then all over the place.
RC51TOFUMAN
in Thee OC
Can anyone confirm the replacement Molded Lead Frame is an Updated Improved part?
Or is it the same as OEM what's in there currently?
Sent from my SM-G973U using Tapatalk
ogdobber
Its an updated part with new part number. Visually you can see a few differences, I can't remember what they were...i may have taken pics but I'd have to find.
RC51TOFUMAN
in Thee OC
Can you get me the New part number?
Thankyou in advance
Is this Molded Leadframe failure inevitable? Will everyone eventually get this failure?
ogdobber
Thankyou in advance
If you order from tasca the part number is superseded.
Will everyone get it?... Dono, but they have expanded the recall so it's worth checking if your truck falls in.
Mine didn't, leadframe failed and i got a wrench and it wouldn't go in reverse so i bought the part and replaced myself... Month later my Vin was in the recall
RC51TOFUMAN
in Thee OC
Unfortunately TSB my dealer wouldn't touch it. It has to be a failure or Recall.
Let me this up in Tasca
92,828
56,082
JTRaptor20
