Headlights Always On
Ro_Ja Boy
Las Vegas
I have my headlights set to auto, but they are always on when driving. They don't turn on until I put the car in drive. Is this normal or is there something that's likely been programmed in Forscan by the first owner? Thanks
brianh87
Pittsburgh, PA
The low beams are always on in our vehicle as daytime running lights. They operate at a lower voltage or at a different pulse width modulation signal, so they should be much dimmer than when they are actually "on" low beams.
Raptor911
Ashburn, VA
The low beam are always on if you have your lights set on auto. If you do not want your low beams on then turn off auto.
