Did It — 37”
CO DUSTORM
CO DUSTORM
Monument, CO
No, love it...I researched this for over a year, lots of pro/cons, lots of opinions, lots of confusion, etc. It seems like everyone has a different experience, even if their bone stock -- which baffles me. Stock rims provide the best offset, if you go with aftermarket rims with offsets sticking out further than stock you are likely to experience a lot of rubbing. I was borderline on adding spacers for an even more aggressive look (which would of been like having aftermarket rims) and was warned by 4Wheels Parts and another tire specialist that the rub would be much worse. Luckily these tires appear to stick out a little bit more than the KO's and give it that aggressive look.
Again, I'm on mid-perch, no other changes. When they test fitted the tire we thought they were going to have to make a minor trim of the edge of the front flare at no charge. After it was said and done no trimming was required. My clearance at one point is approx .5", no rub now, possible rub might occur if turning and have hard compression. Will watch closely and if necessary have it trimmed when I go in for a rotation. The most off-roading will be dirt roads while hunting, no serious jumping like many on the forum do.
Tires gave the truck an additional 1.5" lift, can't wait to get rid of my topper at end of year and empty the bed to get rid of the uneven stance.
halojunkie
KS
This post convinced me to do the same. I have the Gen 2 shocks so my front already rides a little higher than stock. I am gonna try the white letter's out just for something different.
I got the K02's in this size for $339 a shot. Can I ask what you gave for your Nittos?
HORN HIGH ACES
Colorado
You'd have to be awfully aggressive to do that on these trails. Pretty much all of it is smooth, but you would have to take it easy in the dunes.
