FINRPTR
So Cal
Cory S,
This is what I am basing my rack on, as mentioned earlier, the outside tire support bars will be parallel with the lower bars to give me a little more room in the middle. I will also be installing a bar that follows the profile of the cab to mount some lights on.
I am exploring ideas to mount a CO2 bottle, oil bottle storage cans, and a set of traction boards.
FordPerf Addict
How did you manage to bury it like that? Hammer it in 2wd? Assuming you didn’t air down? Looks like a 2019... what modes did you try and/or like in the loose sand?
It was in rock mode 4L, I high centered on my second day
The night before it rained all night and was windy so it made the tops of the big hills pointy. Nothing I could’ve done really except have a shorter wheelbase. They day before I made it up no issue.
Also sand mode is perfect for dunes when going 45mph or less. Keeps me in the right RPM for torque so mid to low range. Any high speed I just used baja mode.
I ran 20 psi in the front and 17/18 in the back. I didn’t wanna run it any lower as I was cruising over whoops from 45-60mph and didn’t wanna blow my tire off the rim during power slides. Truck performed amazing I really appreciate how good this thing is. At first I was going over whoops at 20/30 and it was rough. I remember reading the faster the better and I tried it and it was the best move I made!
Was important to note it was wet most of the time I was there so there wasn’t much soft loose sand at all
