Roush engine failure
Killjoy
Kansas City, MO
FYI - We blew an engine last year and Peoria Ford out of Phoenix really did a great job on the new crate motor and reinstalled the Whipple Supercharger I had on it since practically new. At 98k miles it finally threw a rod but we are pretty hard on our truck for offroading so it wasn't without some expectation that it may fail.
Richard is the Parts Manager at that Ford dealership and they do many custom Raptors so I was able to do the new engine swap for around $10k and it's been great ever since. I'd recommend a trip down there if you are serious about getting it replaced. ;)
B
Blackhawk901
CO
Thank you all for your help and insight. The dealer came down on labor and will install new oil pump gears to avoid this from happening. I have a previous custom tune from a session done last year and hopefully this engine failure will not effect the supercharger. I had not thought about that aspect of the rebuild. In retrospect, I would have just done it with some buddies but already had it towed to the dealership to start the work. :( :mad:
Dane
Littleton, CO
New oil pump gears or upgraded? Very important. Do NOT just install OEM gears!
EricM
OHIO
The blower should be fine. Might want to get the intercooler cleaned while it's out though, it's probably covered in oil from the PCV system.
