COBB Accessport Issue
RGVRaptor
South Texas
Trying to upload updated Stage 2 tune to accessport. When I try and get it from my computer to the accessport, it says "Are you sure you want to copy these 0 files to your accessport?"... Right there it's telling me that something is screwed up. Zero files? When I try and upload, drag and drop, etc. Nothing happens. Literally can't get the map to upload to the accessport through accessport manager. Tried ejecting accessport and plugging back in, nothing.
Any ideas?
COBB Tuning
Austin, TX
You are able to install the Accessport without downloading anything. The maps are already on the Accessport!
To explain the issue you're having, the file downloaded is a "map pack" which contains ALL files for your vehicle. ALL meaning every model year, ECU ROM version, market, etc. In order for this to work, the Accessport would need to be installed so APM knows which of these maps to transfer. I'm sorry for the hassle! This is something fairly new so expect it to be improved in the coming months.
Kyle@COBB
Erik
Warsaw, IN
Can everyone else leave their accesport on without it draining their truck battery? If I leave mine on the dash lights up every 30 seconds and it must bring the whole truck online every 30 seconds because it completley driained the new battery in the truck the first night I had the accesport. Cobb had me put the accessport on a setting that enables the anto on/off of the accessport which stopped the truck battery drain, just wondered if anyone else has this issue or if I'm just unlucky. My fear is one of these times the access port isn't going to shut itself off and I'll come out to a dead Raptor again.
WC114
I've been leaving it installed for a couple months now. No issues sometimes it'll leave it sit for a couple days without being started
cdurbin
Lebanon, IL
Agreed. I’ve had mine several months with no issues.
-Corey
Seartrip
I'll admit I didn't have the auto on/off set, and it killed my battery deader than snot. Lesson learned, my fault.
TwizzleStix
Pudendum Inspector aka FORZDA 1
Commivirginia
Note I’ve had the AP in different vehicles for over a decade now. Just make sure you set the on/off to auto and all is well.
ALSO NOTE that it uses the battery voltage to turn on/off, so if you have a peak voltage controlled charger on the battery like in a vehicle you don’t drive much, when the battery/charger hits the trip voltage the AP will turn on even with the engine off. No big deal except the AP is on in a stored vehicle.
Just remember to unplug the AP if you have the car a on a charger!
