Factory Keypad Code?
MJK
My used 2018 didn’t have the door key code in the manual anywhere. Or my paperwork. Before I call the dealership, is there a way for me to retrieve this myself?
goblues38
STL
youtube it...take apart the passenger kick panel...the door module is in that panel....the factory code is behind that module on a sticker.....it is a pain....but you can read the code with a flashlight after you remove the panel
MasterWaterSkier
Houlton, WI
I just bought a 2013 Raptor and the keycode was not with the vehicle. If you have 2 keys, this will work.. Put the first key in, start the truck.. pause a second or two... shut the engine off.. put the second key in start the truck.. pause a second or two and the key code shows up on the screen. The screen where the mileage is, not the nav/sync screen.
Not sure if it works on your 2018, but I just did it on my 2013.
500mag
Georgia
Or, the dealer can interrogate the computer fairly quickly, and print out the code for you. As the above poster stated, the factory code cannot be deleted.
