PBR ME
Hit the diff and rear axle with some self etching primer and a coat of satin black...
Turbogoat324
SoCal
Installed a set of SVC trac bars. Took a little longer than expected to weld because I didn’t take into account that you have to drop the gas tank and exhaust. So far impressions are great! Even on the freeway the rear end feels much more planted over those offset bumps that used to make it jitter a little. And of course as anything I’ve gotten from SVC, fitment was perfect!
nikhsub1
Los Angeles
Changed the oil which requires me to pull the bumper to get to the filter - it's not that bad but kind of a hassle. I installed clip nuts on the ADD skid plate so I can just remove the plate and hopefully get to the oil filter without having to remove the entire bumper. I also installed the Ronin Factory drain plug to make future drains mess free.
Kashoggio
Lives in a van down by the river.
Hit amazon late at night and home some cheap stuff
Shorter antenna that still has a little flex to it
Add on center console tray
I added the rear driver seat latch thingy from builtright but not sure if I will ever use it
