Running wire from engine compartment to interior
pastorwug
Santa Maria, CA
I wanted/needed a heavier duty wire than the 16-18 gauge wires that Ford has running through the dash.
The ARB Fridge/Freezer is more comfortable with at least 8-10g
dewalt
The wires Ford run do not look heavy enough to run a cell phone charger.
zombiekiller
OG BooBooRunner
New Orleans
the wires ford ran are rated for 25% over what the circuits are fused at. (amperage-wise)
and some of us are running quite a bit of electronics and need 10 more switches. I've got all 6 aux switches, and additional 2 discreet switches, plus an 8 position sp9100, all spoken for.
so yeah, running more wiring is required.
rsbug
N Texas
How did you route your SP9100 wire from the overhead console.....through the right side?
zombiekiller
OG BooBooRunner
New Orleans
under the headliner ina loom of chafe guard with my dashcam harness, then down the passenger side A pillar, then through the factory firewall grommet.
rsbug
N Texas
Thanks.....I wasn’t sure if there was a location on that side that already had a factory grommet....but I haven’t looked up behind the glovebox
zombiekiller
OG BooBooRunner
New Orleans
yep. its easiest if you pull the passenger side front fender liner.
If you unplug the computer on the back side of the passenger toeboard, dont freak out when none of your dash lights work. (why they put the dash ecm that low on the body, I have no idea.)
rsbug
N Texas
924551D6-4C87-480B-9DA2-2CFFC74F8E92.jpeg 77D82E54-C90C-43C4-88F3-E9FDCE02D86B.jpeg
I went through a location up on the passenger side where I discovered a existing grommet about the size of a nickel. Still determining a location to mount the power module in the engine compartment. Any ideas?
wheelman55
Big Bend or MN
I run ARB fridges in both of my trucks. I route to both cab and bed. I use 10 gauge inside the cab and 8 gauge in the bed, since routing to the bed is longer.
Gotta keep voltage drop in mind.
