Baja Designs: General Discussion Thread
Baja Designs
Baja Designs
The Scientists of Lighting have figured out how to drive our LEDs harder, safer and more efficiently. Almost half of our LED products are now BRIGHTER, BOLDER, BETTER.
XL Sport and Squadron Sport LED auxiliary lighting
up to 30% BRIGHTER
- Increase lumens from 2,260 lumens ⇒ 3,150 lumens
- Increase watts from 20 watts ⇒ 26 watts
- Increase amps from 1.4 amps ⇒ 2.0 amps
S8-series LED light bars (per 10” section)
up to 40% BRIGHTER
- Increase lumens from 4,520 lumens ⇒ 6,350 lumens
- Increase watts from 45 watts ⇒ 60 watts
- Increase amps from 3.2 amps ⇒ 4.0 amps
OnX6+ LED light bars (per 10” section) up to
69% BRIGHTER + includes new Battery Management Technology
- Increase lumens from 7,350 lumens ⇒ 12,450 lumens
- Increase watts from 58.5 watts ⇒ 108 watts
- Increase amps from 4.2 amps ⇒ 8.4 amps
HI-POWER IS OUT, PLUS IS IN!
We are dropping the Hi-Power line, but offering the brighter and more affordable OnX6+ light bars with a starting MSRP of $429.95. Not only is the OnX6+ line brighter, but we are integrating brand new technology at the same time. Baja Designs’ new Battery Management Technology (BMT) is a game-changing feature designed to keep your lights running at your vehicles maximum potential. This additional protection allows us to drive our LEDs and circuit boards harder, without risk of failure or damage. When your vehicle’s voltage drops below 13.5v, your light will begin to gradually dim until voltage is stabilized. BMT eliminates flickering under low voltage and protects your vehicles wiring and electrical system from dangerous current spikes.
raptor36
Awesome! I love it. Question for you. Do the LED’s in the LP9 not get an upgrade too? If not, I am just curious, for the sake of understanding, why not? Thanks :)
Baja Designs
Baja Designs
The LP9 is currently running at full potential. We are always looking for ways to improve our products, it's certainly possible the LP9 will see updates in 2019.
Baja Designs
www.bajadesigns.com
rkneeshaw
Northern Michigan
Hey bailey, can you tell me more about how the onx6+ differs from the hi-power version? Looks like its only about 1600 lumens brighter (24,920 compared to 23,300 for the old hi-power, both 20"). And the + gets the BMT. Is the wiring the same with the dimmer circuit for a direct swap? What else is different between the + and the hi-power or is output pretty much the same now?
Baja Designs
Baja Designs
The Hi-Power output is almost exactly the same as the OnX6+. We changed the branding around when removing the standard OnX6. The Hi-power and Onx6+ share the same wiring
Baja Designs
www.bajadesigns.com
Baja Designs
Baja Designs
OnX6, Hybrid LED and Laser Light Bars
Our new "Hybrid" LED Laser Light Bar gives users the ultimate lighting package. We have combined two of the most advanced types of LEDs with laser chips through our High Speed Spot optic to deliver a far reaching, yet smooth blend of light — elevating forward projection up to 30-40% farther than our current Hi Power OnX6. If you want to stay ahead of the competition with the farthest reaching product on the market, look no further.
Baja Designs
www.bajadesigns.com
