GEN 1 Shock perch question
Jhollowell
Everett, wa
So my shock rebuilder kind of screwed me. I refinished my shocks and clear coated them before sending them out to get rebuilt. In the process i removed the lock rings that hold the perch in place by cutting them off. I bought new ones and clear coated them as well. I tried to install them with some large snap ring pliers but couldn’t open them big enough to get them over the lower lug. So i asked the shop to put them on when they had the top cap off and could take the perch off and put the lock ring on from the top. Well they didn’t so now I’m stuck trying to get that damn thing on. Has anyone had any luck getting it on without disassembling the shock? It might go on if i take the lower bushing out? That seems like a tough job though? Anyone have any suggestions?
Chiefapple
Milwaukee, WI
Lol, the shock rebuilder screwed you? Sounds like you screwed yourself and then didn’t ensure that someone else would fix it for you. Good luck getting that on without taking the shock apart.
J DAMAGE
NJ
I have my blown shocks in the basement, give me a few min, I go pull it apart and see if theres a way.
Chiefapple
Milwaukee, WI
I have a set here also, but I also know that the perch can’t be removed or added with the shocks assembled. I’ve been wrong before, so good luck.
Best advice I have is before accepting the parts, ensure they did what they were supposed to.
Jhollowell
Jhollowell
Everett, wa
Maybe my mistake that i didn’t ask that they did install them. I sent them out to have them rebuilt so i didn’t find out till i opened the box. The rings were zip tied to the shock so there’s no way they didn’t notice them. I do have the email with me telling them to install them. We’ll see what they say on Monday.
Chiefapple
Milwaukee, WI
I would guess that wherever you went then, sent them back the same way, hence the zip tie. Hope it works out for you, but the shipping is going to cost someone.
J DAMAGE
NJ
The perch it self, can not be removed or installed with out the shock shaft and cap removed, if you mean the steel ring clip for the perch, it can be done, a little of a pain not to scratch the shock,
Chiefapple
Milwaukee, WI
If it’s just the snap rings, that’s a whole different story. Stop using an expander though and start rigging up a setup to get them on. It won’t be pretty, but it’s doable.
Jhollowell
Jhollowell
Everett, wa
It’s just the rings. I’ll pick up some larger lock ring pliers and try again
J DAMAGE
NJ
2 small vise grips clipped on ring at 10 o'clock and 2 o'clock , shock upside down( shaft down) pry clip open just enough to slip it over and down the shock, the clip will be a little loose now, but pinch it closed with your fingers, as you slide the perch over it, the clip will engage into place, set the perch to the correct position perch and tighten set screw. take caution not to scratch your shock. if my wife was around, i would of made a video , but only have two hands,lol
93,145
56,419
TwistAir
Latest posts
