Check out our Gen 2 Raptor Build!!!
customtruckshop
LGE-CTS Motorsports
San Dimas, CA
One of our recent builds for a customer, here is what we did so far:
Custom "In House" build Front and rear bumpers
Custom "in House" build bed cage and spare tire mount
Rigid Light bars, pods, chase lights
Fox 3.0 Finned Resi bypass F&R shocks
Camburg Upper Uniball Arms
BFG KR2 37x12.50R17 Tires
Method Beadlock wheels
Borla Exhaust
We are currently adding a Whipple Performance intercooler and tune kit
If you need anything for your Raptor or have any questions on the build give us a call!
(909) 599-2228
Ask for John or Dale
customtruckshop
customtruckshop
LGE-CTS Motorsports
San Dimas, CA
If you are referring to ride height adjustment we can bring the front coilovers up about a inch.
As far as compression, rebound and other shock valving and tuning these shocks do have a optional Dual Speed Compression knob, in their own words: "Add remarkable versatility and precise tuning with new DSC. A simple twist of either two adjuster knobs allows 10 separate low-speed and 12 high-speed compression levels. Included new black anodized aluminum reservoir increases cooling efficiency."
We have other access to fine tuning the shocks as well.
Hope this helps, Thanks
DEGBTI
San Diego
couple questions, how much more did you have to preload the front springs than what they are pre-set at from fox to clear 37's"? I just installed a set of fox front shocks and it leveled my truck, but not sure I can run 37" off road. Did you make any other mods for clearance? Also, Can you please PM me a price on those tires?
thank you!
oh, and how did the tire balance? are you able to drive on pavement without vibration?
customtruckshop
customtruckshop
LGE-CTS Motorsports
San Dimas, CA
Our customer beats his truck pretty hard so we did not adjust the preload out of the box, however we did have to do a body mod by cutting back and welding in a smaller plate at the body mount which we do for $900.00.
I will PM you the price on the tires.
As far as the tires they did balance out ok and drive fairly smooth on the street but they do wear very fast on the street.
Hope this helped, thanks.
DEGBTI
San Diego
got the pm, thank you! Ill keep in mind the body mount idea too
