What do you run for Tire Pressure on/off road???
Fender
Reviving an old thread. Is airing down to 25 psi okay? Gen2 with regular 17s, no beads
ogdobber
I run 48 at home, 32 in mex (shit roads) also any offroading, and 15 in sand. (No beadlocks btw)
Deleted member 12951
GEN2’s at Raptoberfest were running 25 but be aware of corners and try not to power drive it into it otherwise you will take off a bead. Several folks did.
Jimster58
Greensboro, NC
prolly not that significant...but nitrogene doesnt increase or decrease with ambient temps...and keeps moisture out, which help prevent increase or decrease in tire pressure. Might be full of ****, but i do know we use nitrogene to dehydrate refrigeration systems at work, and it was free...so i dont see how it can be any different from your tires. here is the link:
NitroFill Nitrogen Tire Inflation
Nitrogen - being a gas as present in a tire (or atmosphere, for that matter at ~79% of what we breathe) is still subject to gas-law behavior, regardless of marketing gimmicks and claims. It will increase in volume if it gets hot, and decrease in volume if it cools. In a confined space/fixed volume, that translates to a pressure increase and pressure decrease on heating/cooling.
Wilson
South Dakota
I have mine at I think it's 44 psi if I get stuck I have a buddy pull me out haha haven't been stuck yet but only snow mud. sand sucks the key is to not spin your tires
Frank N
NJ and Outerbanks
17/18 in the sugar sand, I have run as low as 12 when it was super soft in other 1/2 tons without issue, no beadlocks but also only driving at 15 mph in 4 lo
