6.2 intermittent valve train ticking noise at start up ??????????????
FordService
The local dealer took her for a week trying to duplicate the noise on startup to no avail. I'll post if I'm able to resolve the problem. Thanks
Thanks for the update, SERG09. If this starts happening more reliably, I'd recommend returning to the dealer so you can demonstrate it for them. If you head back in, send me a PM with your details (full name, best daytime phone number, VIN, current mileage, and servicing dealership); I'll notify your regional customer service manager and have them give you a call.
Crystal
Monumentins
I have a 2014 make noise as others have posted on start up, whether cold or hot... Sometimes when cold but not hot and sometimes when hot but not cold but usually makes the noise ( sounds like lifters clattering ) also have a solid sounding thud drivers side wheel well and most recently seems the exhaust is muffled. Truck doesn't have the throaty rumble it had when I first bought it. Low RPM power seems somewhat sluggish and if throttle is applied slower at normal speeds seems kinda sluggish and stumbles some what and slow to downshift. Anyone having / had any similar issues???
crashmc302
North Carolina
Valve-train noise on startup is NORMAL
What amount of ticking is acceptable while it runs? Mine goes away at 1800 RPM but can be heard from outside the truck on the right side of the vehicle. It won't let me post a video or I would.
Sent from my SM-G930V using Tapatalk
GizmoVance
NO amount of "ticking" is normal AFTER initial startup. It should go away within seconds.
Depending on how sensitive your hearing is, if you hear a "purr" of "clicking", that can be normal and is the INJECTORS, NOT the valve train. This is different that what I am referring to with the very mechanical CLACKING noise heard as the 6.2 if fired up. This is usually after a hot shutdown, whereas the lifter rack becomes drained and dry since the oil has become thinned out.
HTH
crashmc302
North Carolina
HTH
Yea, I've always heard that noise on start up and ignored it because of that reason, but the ticking I'm talking about is after all that and unilateral. Meaning on one side only and I'm not sure how mechanical it could be. I can't hear it in the cab though. I've heard of injectors making that noise, but I don't know how fast they tick or how noisy it is. This doesn't sound like 8 injectors firing in sequence. Unfortunately I don't have the money at the moment to have a dealership dig into the motor. I noticed it off roading in NM and it made it all the way up to Denver and then home to NC without getting "worse". My buddy's Raptor doesn't even make the slightest noise and he's at 130k and tows a horse trailer with a goose neck attachment in the bed. Mine is at about 103k after all that driving (NC to Houston to northern NM to Denver to TN then home), so I'm sure there are a bunch of things that are going to start popping up. I just no longer have a second vehicle, so shop time isn't ideal either. Just have to wait for a work trip that's at least a couple months long. I'm sure a ton of folks are gonna face palm after reading that, but I didn't have a choice but to drive back to NC like that. It's since sat in the driveway.
EDIT:
While I was in NM I did an oil change due to all the driving I was doing and still needed to do. I decided to also try a remedy for valve ticking. Figured what could be the big deal? High mileage engines start doing stuff like this at some point. Used the Lucas engine oil treatment with 5W-20 high mileage full synthetic. Since getting back to NC (a little less than 3,000 miles later), I haven't heard the ticking (knock on wood). I'll likely start using 5W-30 since my truck is at 104k. Spark plug change showed some dirty plugs and one wire that was disconnected for who knows how long. So new wires are in order. Didn't want to do just one. Would that cause the ticking? I'm not sure how far off the end of the plug it was, the sound I heard was similar to the snap or tick you hear when testing a spark plug.
mike0378
my truck did the same thing and it ended up being an ignition coil on the passenger side.. my raptor has 133,000 miles on it and it just stared doing it
---------- Post added at 04:16 PM ---------- Previous post was at 04:01 PM ----------
I have a 2011 Raptor with 133,000 miles.
mine did the same thing and it ended up being an ignition coil on the passenger side. it would make a ticking noise
