Deleted member 12951
Nice foam! I'm jealous of your weather, seeing your neighbors are out in shorts!
Actually it was a freaky warm day today, blew the old record from 1999 of 70 away. It was 82 today and its February winter here. Tomorrow its back to 40-50's. I couldn't get it all done (since I did my wife's car first) and tomorrow plan on finishing but probably not in shorts this time.
Lugnut2683
Temecula, CA
Installed my RPG bump stop kit... but the kit was missing the screw head cap bolts that are needed when retaining the factory rear spring block. So I left the bump stops and striker plates off for now until I get the set of screws (hopefully early this week). Looking forward to testing the setup out in Black Rock Desert this March!
DrewFish11
Vallejo, CA
Nice. How do you get away with not having a front license plate?
The same way I get around having my front windows tinted. I don't ... if I get pulled over I'll get a fix it ticket... get it signed off... and then move on. I'm a gambling man lol also, this isn't my daily so my risk is diminished.
Iziks
O’Fallon, MO
What paint did you use? Needing to do the same to mine. Been debating on using a bedliner spray.
3M professional undercarriage paint. It is a rubberized compound that comes in a spray can. Very easy to use and I was really happy with the results. Same texture as the bedliner spray. We will have to see how it holds up long term. Plan on about a can and 1/2 for each side.
t_j
Chicago, IL
Picked up the cap from paint yesterday
Waiting on the electric lock for the glass so I can tie it in with the pop and lock on the tailgate.
Need to wire up the lights to my existing bed lights fit the alarm sensor to the glass and reinstall the 3rd brake light. Once the paint has had some time to cure the roof will be going black like the cab roof and getting a matching rack.
