Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exhaust and Cutouts Discussion [GEN 1]
Y Pipe Leak Help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="guitarist982" data-source="post: 989680" data-attributes="member: 17101"><p>Same issue, same spot. Did you loosen the clamp in order to ratchet it back together and then tighten it up or just put a ******** it and crank it down? I had a hard time getting a wrench on it with the bolt installed from the top, but was tight as best as I could tell.</p></blockquote><p></p>
[QUOTE="guitarist982, post: 989680, member: 17101"] Same issue, same spot. Did you loosen the clamp in order to ratchet it back together and then tighten it up or just put a ******** it and crank it down? I had a hard time getting a wrench on it with the bolt installed from the top, but was tight as best as I could tell. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Chewie
k3k0a808
motostar2888
Badmofo82
MZRaptor72
cuts
thatJeepguy
Punkur67
jzmundy
tst
smilie430
Reptar854
pat247
Nick@Apollo-Optics
CleverGirl_
someday
Frogger22
Dev
encyphered
daytona1783
Booth9999
Derrick Hernandez
CF109
IIAWAH808
HORN HIGH ACES
bakwaas4eva
Turning Blue
MyBallZachErtz
Badboy4fun_wa
GCATX
LayinWatts69
hamster
rfranklin1
JohnyPython
04Ram2500Hemi
raptordawg1
whatthetruck
BushwiickBill
k9lovr
Johnny@Apollo-Optics
Sozzy12
PlayNDirt
Seven Twenty
Mossy 150
Rigged_Up_Raptor
Arizona Free
WTX
pirates1456
Luchh224
c0b2a
... and 29 more.
93,279
56,566
erikn
Forums
Y Pipe Leak Help
Accept
Learn more…
