Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Wiring Vision X LED Light Cannons with Vision X Harness
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="svt_reid" data-source="post: 909706" data-attributes="member: 17118"><p>Okay thanks. That's what I was needing to know. I'm gonna just wire it to the aux switch and use the little pigtail connectors instead of the whole harness. I was just curious as to why it had such big fuses. My twenty inch rigid has a 15 amp fuse. It's not making sense to me why they send a thirty amp fuses for one little LED. Anyone else care to chime in on what size fuse yall are using? I may be totally off on this because I just don't really understand low voltage dc stuff that well. I work on high voltage ac lines. So I wouldn't want to over fuse it and burn an LED up or something like that. (Not sure if that is even a possibility.) someone enlighten me please</p></blockquote><p></p>
[QUOTE="svt_reid, post: 909706, member: 17118"] Okay thanks. That's what I was needing to know. I'm gonna just wire it to the aux switch and use the little pigtail connectors instead of the whole harness. I was just curious as to why it had such big fuses. My twenty inch rigid has a 15 amp fuse. It's not making sense to me why they send a thirty amp fuses for one little LED. Anyone else care to chime in on what size fuse yall are using? I may be totally off on this because I just don't really understand low voltage dc stuff that well. I work on high voltage ac lines. So I wouldn't want to over fuse it and burn an LED up or something like that. (Not sure if that is even a possibility.) someone enlighten me please [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
Todd Turbo S
Rednose
RedlineHD
XtraSpclCrspy
dfw62
samwelll
bellnghmrider
GCATX
SentIt
karna
brettmess24
thatJeepguy
kevo_lo
thechamp408
eSos55555
RRick
AngelMomma101
taquitos
chadinokc
Griffin
elpechedepeche
ToadSmasher2K1
hdvvraptor
kocher93
BlueJeansOverland
bigboy
Cronn99
p3t3
engineer
trailerjack
Braaaptor_Trav
Raptor_NV
n00dler
green7
AZEngineer
ReddingRaptor
FmaxTurboSi
Turning Blue
weiser27
Stroked out
kem12993
zachery55
93,273
56,557
oRoarke
Forums
Accept
Learn more…
