Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Wiring Advice
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SlkRptr" data-source="post: 1275936" data-attributes="member: 27633"><p>I actually ended up putting each pair onto a separate switch. The wiring wasn't bad but after looking at it I didn't want 6 wires being connected to that small of a wire for the upfitter switch. Also in my state (Virginia) you can get a ticket for displaying more than 4 lights (white, front facing) on public roads. Think of lo beams + fog lights or High beam/low beam. That also factored into wanting to run at least one of the lights as a fog light and have the other 2 available for beach riding. I think it is possible because the draw in lower than the rating, but for the reasons above I just split it all up.</p><p></p><p>I have 4 of my 6 switches used up but I have room for backup pods and another accesory if I ever choose to get one. Also if you have an 18 make sure you use the correct loom towards the center of the engine bay and seach for the correct wiring colors as it doesn't match the manual.</p></blockquote><p></p>
[QUOTE="SlkRptr, post: 1275936, member: 27633"] I actually ended up putting each pair onto a separate switch. The wiring wasn't bad but after looking at it I didn't want 6 wires being connected to that small of a wire for the upfitter switch. Also in my state (Virginia) you can get a ticket for displaying more than 4 lights (white, front facing) on public roads. Think of lo beams + fog lights or High beam/low beam. That also factored into wanting to run at least one of the lights as a fog light and have the other 2 available for beach riding. I think it is possible because the draw in lower than the rating, but for the reasons above I just split it all up. I have 4 of my 6 switches used up but I have room for backup pods and another accesory if I ever choose to get one. Also if you have an 18 make sure you use the correct loom towards the center of the engine bay and seach for the correct wiring colors as it doesn't match the manual. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Maehr
julien194b
im33303
0341Marine
sct
kocher93
Frogger22
KMO
MOTOR10
Socks
Vegas2020
IDI-Charlie
fastford4x4
pilot545
thechamp408
IIAWAH808
93,570
56,848
AZBajaRaptor
Forums
Wiring Advice
Accept
Learn more…
