Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Engine Discussion and Performance Mods
Whipple issues?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="beerhasvitamins" data-source="post: 288166" data-attributes="member: 6587"><p>Alright this thread is getting long so I am going to summarize.</p><p></p><p>Low boost and fuel trims 10+. Vacuum leak on rear of blower due to loose bolt. Problem corrected. Boost is normal and trims are much better.</p><p></p><p>Ambient air stuck at 60. Whipple has corrected the issue in an updated tune. Call Whipple!</p><p></p><p>Surging idle. Its in the tune. Basically the tune is too sensitive and is over correcting trying to smooth the idle. It is actively being fine "tuned". Mine has corrected itself on its own with the new tune. Also had a slight exhaust leak at the manifold which helped I'm sure. Long term trims don't show leaner bank anymore(7-8% compared to 3%).</p><p></p><p>Autostart issue? I will check tomorrow. I rarely use it!</p><p></p><p>Exhaust mods causing issue? No. Required back pressure is achieved from the cats and exhaust manifolds. I asked Mike before hand. It is not designed for it but is not out of its limits to adjust for. It is based off of the GT500 tune! The tune is the best there is and even compensates for the upgrade kit which is a 3.5" pulley vs 3.65". Not sure exactly how much boost it added but Mike said around 1 psi due to the larger intercooler. I'm not looking to start a forum war here so if you don't want to believe this then don't. Call Whipple. Maybe they found something new!? I seen no noticeable difference in short term trims while opening and closing the cutout.</p><p></p><p>Issues here are resolved and I am a happy customer. I learned a lot between my calls to Whipple and various tuners so it was worth the time I put into correcting these issues. Thanks to all who replied!<span style="color: Silver"></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"><span style="font-size: 9px">---------- Post added at 01:51 AM ---------- Previous post was at 01:41 AM ----------</span></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"></span>[ATTACH=full]199828[/ATTACH]</p><p>Heres what we are working on BTW. =)</p></blockquote><p></p>
[QUOTE="beerhasvitamins, post: 288166, member: 6587"] Alright this thread is getting long so I am going to summarize. Low boost and fuel trims 10+. Vacuum leak on rear of blower due to loose bolt. Problem corrected. Boost is normal and trims are much better. Ambient air stuck at 60. Whipple has corrected the issue in an updated tune. Call Whipple! Surging idle. Its in the tune. Basically the tune is too sensitive and is over correcting trying to smooth the idle. It is actively being fine "tuned". Mine has corrected itself on its own with the new tune. Also had a slight exhaust leak at the manifold which helped I'm sure. Long term trims don't show leaner bank anymore(7-8% compared to 3%). Autostart issue? I will check tomorrow. I rarely use it! Exhaust mods causing issue? No. Required back pressure is achieved from the cats and exhaust manifolds. I asked Mike before hand. It is not designed for it but is not out of its limits to adjust for. It is based off of the GT500 tune! The tune is the best there is and even compensates for the upgrade kit which is a 3.5" pulley vs 3.65". Not sure exactly how much boost it added but Mike said around 1 psi due to the larger intercooler. I'm not looking to start a forum war here so if you don't want to believe this then don't. Call Whipple. Maybe they found something new!? I seen no noticeable difference in short term trims while opening and closing the cutout. Issues here are resolved and I am a happy customer. I learned a lot between my calls to Whipple and various tuners so it was worth the time I put into correcting these issues. Thanks to all who replied![COLOR="Silver"] [SIZE=1]---------- Post added at 01:51 AM ---------- Previous post was at 01:41 AM ----------[/SIZE] [/COLOR][ATTACH=full]199828[/ATTACH] Heres what we are working on BTW. =) [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kylesatx
IHAVETWO
ADDRAPTOR
Reptar854
stonecrusher
Lifted&slifted
13terrain
brettmess24
Punkur67
Monkish1
RRR19-Mike
37 Rapt NC
bluewidowr1
NickyF25
Ruger
BoostCreep
dsa6953
Boss 2731
KingKoopa17
Kahuna
ljn21
Advcgh
Space Ghost
Powerlies
mleaky
Irregular F150
pyro_bob
pmariolo
MurderedOutSVT
BIGW0RM
White24RR
dh2002
raptorgroyper
AZ35
xlover
BahaBlastediam
DFS
Muchmore
SeasickLI
Dnovakovic4
friscojosh
fordfreek
nikhsub1
dfranks
trav7314
jpluc26
Haydel53
RaptorFun
matt_carmody
cheese
... and 11 more.
93,454
56,732
The Mad Lad
Forums
Whipple issues?
Accept
Learn more…
