What 40" light bar for the upper grill?
J
Jcsquared
Thank you very much for everyone's responses. I have decided to go with Rigid as I already have 6 Rigids and like how white they are and the others are not as white. Also the ease of installation and clean installation. I was able to get the E series 40" for just under $1,000 seems like a great deal and only 400 more than the others.
RSiWORKS
S.C.S. Michigan
KC LZR 40" LED Light Bar
Single 40" LED Bar with complete Wiring Harness, KC #326
240 watts
16000 Lumens
23 year warranty
PM me for a special FRF price
Stepside
:hmm:Hmmm, I've never seen a 40" light bar in the Upper grill.
I have 30" light bar in the middle.
:birgits_tiredcoffeeWho has a picture of a 40" light bar in the Upper grill.
jnall
Helena, Al
I have used up upfitter 1 and 2 for cube lights. #3 says 15 amp. I have a 20 amp light bar to install and want to use # 3. Can I put in a 20 amp mini blade and be ok?
SwampKing
Use up fitter 1or 2. You can upgrade the fuses on 1&2 to 40 amp even though they're 30amp from ford. The wiring is maxed at 40amps though on 1&2. The wiring for switch 3&4 are already maxed with the wiring size stock.
I have my up fitters like this:
30" behind grill with 2dually white spots on switch 1
40" behind grill with Hood mounted light cannons on switch 2
Amber rings and amber 2duallys on switch 4
Rear TMX bed mounted green rigid dually's on switch 3. I'll be using all my rear mount lights in the future on switch 3
I'll be using switch 1 again for my lightrack mounted LEDs with upgraded fuse to 40 amp at a later date.
