Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Maintenance Forum
Unknown noise?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mygreyf150" data-source="post: 1388392" data-attributes="member: 28541"><p>Just had the exact same problem! It was the vacuum lines for the 4 wheel drive system. easy fix! check the lines and find the one that is cracked or broken. The one line is a stiff plastic and from all the heat and cold they go really brittle and snap. I went to the auto parts store with a small piece of the rubber hose and a small piece of the plastic, found the same stuff and made a small fix. Bam no more noise !</p></blockquote><p></p>
[QUOTE="mygreyf150, post: 1388392, member: 28541"] Just had the exact same problem! It was the vacuum lines for the 4 wheel drive system. easy fix! check the lines and find the one that is cracked or broken. The one line is a stiff plastic and from all the heat and cold they go really brittle and snap. I went to the auto parts store with a small piece of the rubber hose and a small piece of the plastic, found the same stuff and made a small fix. Bam no more noise ! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Viewsflores
jfondren3
riv
TomDirt
SoCal M
quattrojim
BT-Phx
cfabrizio
MZRaptor72
rainhoff
jekyll537
PNTitBLK
willwork04
Irregular F150
alockbox
BahaBlastediam
jAKe47
Russ103
Dev
Herc95
ToadSmasher2K1
hamster
weimer
njhummer18
relak
thatJeepguy
Nj_Raptor
RaptorJoe331
Ryebread86
MDJAK
ausmark
Blown00gt
Nick Masturzo
Wartman
mcasseba
rockyraptor
nniezgor
93,190
56,469
ngodavid23
Forums
Unknown noise?
Accept
Learn more…
