Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Swapping springs on Icon 3.0's
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ntm" data-source="post: 1025220" data-attributes="member: 2412"><p>The full soft position is still too harsh on fast, high frequency hits.</p><p>The spring rate is around 100 pounds higher than the fox's, but it's kind of necessary due to the way a non bypass shock works.</p><p>You can have the damping to deal with big stuff, or the damping to provide a nice ride at lower speeds, but you can't have both at the same time.</p><p>The internal bypasses, or external bypass dual shock setups, do give you both.</p><p>The guys that don't mind the icons, or kings, tend to be going from smooth highways directly to banging sandy, rolling whoops. They don't get a lot of time on choppy clay based stuff.</p><p>Bottom line, bypasses rule...</p></blockquote><p></p>
[QUOTE="ntm, post: 1025220, member: 2412"] The full soft position is still too harsh on fast, high frequency hits. The spring rate is around 100 pounds higher than the fox's, but it's kind of necessary due to the way a non bypass shock works. You can have the damping to deal with big stuff, or the damping to provide a nice ride at lower speeds, but you can't have both at the same time. The internal bypasses, or external bypass dual shock setups, do give you both. The guys that don't mind the icons, or kings, tend to be going from smooth highways directly to banging sandy, rolling whoops. They don't get a lot of time on choppy clay based stuff. Bottom line, bypasses rule... [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
debauch
gjw535
pat247
Skyfrog
Spike Spiegel
tominphx
Telecaster480
Nick@Apollo-Optics
Jay_P
decodo
MZRaptor72
RobSpring661
elking
Speedhunter
MurderedOutSVT
GooseTuned
billw
Dunn
ausmark
mprice1234
scottybs
Ruger
Rptrrob702
Reptar854
awd5906
bakwaas4eva
HeyItsARaptor
Jepper84
MORaptor
mobin
hamster
HORN HIGH ACES
someday
Hard R
GCATX
jAKe47
Braaaaptor
eljefe_tx
daveh8541
CecilK12
LayinWatts69
Punkur67
VJDWashington
FP_RPTR
steveo1103
dsg2003mach1
ToadSmasher2K1
Gumby
ScottS23
Bowlmsc
... and 21 more.
93,198
56,485
bjorn-dpc
Forums
Accept
Learn more…
